Date/Time: Fri, 31 Jan 2025 00:07:43 +0000
Two CGQ connections on same SierraChart feed
View Count: 764
[2019-04-05 00:50:11]
patrader - Posts: 92
How can I use two different CQG trading connections (at two different brokers) on the same SierraChart datafeed on the same computer?
Date Time Of Last Edit: 2019-04-05 00:50:49
[2019-04-05 18:39:29]
You need to install a second instance of Sierra Chart :
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
You will need to activate a second real-time connection. You can do this here:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#DataConnections
[2019-04-05 23:40:52]
Will that require a second set of exchange fees?
[2019-04-05 23:58:30]
No.
