Date/Time: Sun, 27 Sep 2026 00:00:29 +0000
Sierra Chart Exchange Data Feed
View Count: 1015
| [2019-04-04 17:30:29] |
| User500207 - Posts: 7 |
Hello I would like to study the way the original summary trades work Which Sierra Chart Exchange Data Feed would I need for cme non pro eminis bundle package similar to what I get with cqg bundle?? |
| [2019-04-05 08:46:14] |
You will need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed And you just need to activate one of the CME Group exchanges: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SupportedExchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-05 08:46:31
