Date/Time: Thu, 26 Sep 2024 23:30:50 +0000
excel spreadsheet and values on charts
View Count: 1499
[2019-04-04 16:16:54] |
User918738 - Posts: 31 |
Hi, Is it possible to take data from the excel spreadsheet(or SC spreadsheet) and post it above the price bars on a chart. I have formulas that kick numerical values for each bar in the cells and i would like to display this numerical values from spreadsheet on to a chart. Thanks in advance! |
[2019-04-04 18:21:56] |
John - SC Support - Posts: 34744 |
It cannot be done from a standard Spreadsheet, but you can do it using the Spreadsheet Study along with the Study Subgraphs Above/Below Bar as Text study. Just be sure the results are in one of the formula columns (default of columns K through Z), and then reference the appropriate subgraph in the Study Subgraphs Above/Below Bar As Text study. Here is the documentation for the Spreadsheet Study: Using the Spreadsheet Study: Step By Step Instructions to use the Spreadsheet Study Here is the documentation for the Study Subgraph Above/Below Bar as Text study: Study Subgraph Above/Below Bar as Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-04 20:16:55] |
Sweet...thanks John!
