Date/Time: Sun, 13 Sep 2026 02:05:21 +0000
Text/CSV Data Format real time
View Count: 4051
| [2019-04-04 11:03:42] |
| User21223 - Posts: 97 |
Is it possible to import data in real time. By Text/CSV Data Format. I have data in the Text format. Updated in real time. I would like to import them to Sierrachart |
| [2019-04-04 11:36:00] |
| ganz - Posts: 1048 |
User21223 it's very easy to do Intraday Data File Format use python in case you are too lazy :) Python for Sierra Chart |
| [2019-04-04 13:38:37] |
Thank you for your response. I do not have any contact with programming. Can I ask for a short film of help
| [2019-04-04 14:40:19] |
User21223 https://rooksguide.files.wordpress.com/2013/12/rooks-guide-isbn-version.pdf enjoy! :) |
| [2019-04-04 14:48:16] |
"Write an Intraday file header of type s_IntradayHeader to the beginning of the file. Once this is done, it does not need to be done again. For an understanding of the different fields of the header, see the structure definition above and the comments." I do not know how to do it |
| [2019-04-04 15:45:31] |
User21223 http://www.eecs.umich.edu/courses/eecs380/HANDOUTS/cppBinaryFileIO-2.html http://www.cplusplus.com/articles/DzywvCM9/ Date Time Of Last Edit: 2019-04-04 15:48:23
| [2019-04-04 17:44:03] |
You need to use the intraday data file format: Intraday Data File Format To be able for a chart to read data in real-time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-04-04 19:51:26] |
Ganz, are you able to record an instructional video for me.
| [2019-04-04 21:10:47] |
User21223 there is no make any sense to make a video. in case you really need it just don't rush and learn c++ step by step a very basic c++ level will be enough |
| [2019-04-04 23:38:59] |
User21223 https://www.youtube.com/watch?v=18c3MTX0PK0&list=PLlrATfBNZ98dudnM48yfGUldqGD0S4FFb https://www.youtube.com/watch?v=z2Q1cvotLCk :) |
| [2019-04-05 08:01:12] |
thank you, I started to study ... can you give an example of the codes used for this project. about options Intraday Data File Format |
| [2019-04-05 08:43:12] |
ganz I can ask for [Direct Messages]
| [2019-04-05 14:37:38] |
User21223 - i'm using linux and g++ - i'm using CLI-mode only, no IDE ... so you need to be familiar with it as well - there are a lot of c++ specific forums to make it real >> read and parse csv >> fill a struct and write it to *.scid gd lck |
| [2019-04-05 14:45:25] |
User21223 >> read and parse csv
my preferred way to parse csv : https://futures.io/sierra-chart/26630-hide-show-studies-buttons-study-6.html#post707020 |
| [2019-04-09 11:39:15] |
Unfortunately, I can not deal with this. Is it possible to write a ready application that does it.
| [2019-04-09 11:41:33] |
User21223 no, i'm not interested in. |
| [2019-04-09 11:46:50] |
of course for a fee
| [2019-04-09 13:00:08] |
User21223 i like more people to use c++ and acsil i'm not a programmer so no any deals in this direction and no any fee will be possible sorry to mislead you at all |
| [2019-04-09 13:14:43] |
| Ackin - Posts: 1865 |
User21223) it is not a work for an hour. This and next week I have a job, if you don't need it now and wait, I'll do it for you - free afterwards ganz) i'm not a programmer
it doesn't seem to me that program (gDVAL_pub4) was good
| [2019-04-09 14:09:45] |
Ackin it doesn't seem to me that program (gDVAL_pub4) was good
would you pls provide some feedback in that thread?it really has some new acsil f(x)s that puzzled me i'm not a programmer
yes, i really has no any experience to code for windoze and haven't any intention to study that crap at all
Date Time Of Last Edit: 2019-04-09 14:13:46
| [2019-04-09 14:26:16] |
Ackin ok thank you for the response. I'll wait until you have time |
| [2019-04-09 15:03:35] |
ganz :) .... "that program (gDVAL_pub4) was good" it was meant in good ... I appreciate your work it's funny ... I am attending this forum for several years and in the last time I have feeling from posts that all users of Sierrachart are programmers. And you, who really can something, say that you're not a programmer. User21223) ok Date Time Of Last Edit: 2019-04-09 15:23:24
