Date/Time: Thu, 02 May 2024 22:01:42 +0000
200 Levels (Now 300!) of Market Depth with Sierra Chart Exchange Data Feed
View Count: 7182
[2019-05-23 16:53:47] |
User521555 - Posts: 24 |
Hi, Any news about "We will speak to Bookmap because they should be supporting Sierra Chart for market data and trading using the DTC protocol." ??? thank you |
[2019-05-23 22:24:01] |
No we did not and part of this relates to a permission related issue. So we don't think this is going to be possible after further review.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-23 22:24:31
[2019-05-24 06:46:33] |
EdCarp - Posts: 25 |
I'm still only seeing 20 levels. Is this a function of TransAct limiting the feed, or would this be a Sierra issue?
[2019-05-24 10:59:18] |
You are not using the Sierra Chart Exchange Data Feed. You are using Transact.
[2019-07-22 23:35:57] |
User350051 - Posts: 16 |
Is there. Way to get depth of market with equities?
[2019-07-23 00:06:35] |
Not at this time. We are looking into this, but we do not know if and when that would be available.
