Date/Time: Fri, 31 Jan 2025 00:06:14 +0000
VP settings start/end time cannot span midnight
View Count: 745
[2019-04-03 01:06:15] |
User19165 - Posts: 346 |
The trading day, including the after hours, may span through midnight. When you do this, the current implementation will cut off at midnight and create a new profile for the data after midnight, irrespective of the settings. There are a lot of settings on this indicator so I may have overlooked something, but attached is the settings I have selected.
VP_Settings.png / V - Attached On 2019-04-03 01:04:11 UTC - Size: 34.74 KB - 240 views VP_Chart.png / V - Attached On 2019-04-03 01:06:04 UTC - Size: 18.05 KB - 231 views |
[2019-04-03 17:34:27] |
That little profile is coming from the setting Use Separate Profile for Evening Session. If you do not want the evening session profile displayed, then set that to No. Refer to the following for that setting: Volume By Price Study: Use Separate Profile for Evening Session Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
