Date/Time: Fri, 31 Jan 2025 00:26:26 +0000
Subscription to Sierra Chart Exchange Data Feed
View Count: 930
[2019-04-02 20:10:38] |
User545800 - Posts: 13 |
Team - I have CQG data feed subscription through my FCM. I would like to see charts for SPY. Could I also get Sierra Chart Exchange Data Feed to see it. Please let me know details on 1. Sign up for Sierra Chart Exchange Data Feed to see SPY charts 2. How do I switch to Sierra Chart Exchange Data Feed for seeing SPY and switch to CQG feed to see futures chart. |
[2019-04-03 01:56:43] |
Yes did you require real-time data for SPY? If so, you need to follow through the Setup Instructions found on this page: Sierra Chart Exchange Data Feed You can access the US Equities data at the same time while using CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-03 01:57:21
