Date/Time: Fri, 31 Jan 2025 00:26:32 +0000
[User Discussion] - Adjust chart scaling for ZigZag labels above and below
View Count: 640
[2019-04-02 15:51:07] |
User972768 - Posts: 166 |
Hello, I'm using Renko chart of ES in conjunction with ZigZag study to see rotation size and turning points. It is pretty basic setting for ZigZag. I present these numbers in multiple lines. The issue I experience is scaling of the chart that doesn't take into account these text labels and places highest high and lowest low ones beyond view area. Would it be possible to establish link between study and its chart scale to always keep bars and their labels inside visible area? Similar issue exists for other studies that plot values above/below bars. For example: "Study subgraph above/below bar", "Swing high and low", ... One of the options would be to set number of pixels for region to keep for such labels and use rest of the vertical pixels in the region to scale bars. At least this way I can correlate label font size to "header" and "footer" of the region. Perhaps, this could be done in extra tab such as "Chart Settings >> Advanced Settings 4" where such values could be provided for each available region of the chart Thanks and best regards Date Time Of Last Edit: 2019-04-02 16:10:34
Text_and_scaling.png / V - Attached On 2019-04-02 16:10:27 UTC - Size: 91.95 KB - 237 views |
