Date/Time: Fri, 31 Jan 2025 00:17:04 +0000
Not able to see SPY
View Count: 676
[2019-04-02 15:22:44] |
User545800 - Posts: 13 |
Team - Unable to see SPY in the chart. I am opening chart settings --> Click find button next to symbol --> Going to Stocks --> Selecting NYSE --> Entering Search string as SPY, clicking search by symbol. Not finding the symbol. Chart shows blank as well. How do I get chart for SPY.
[2019-04-02 17:33:25] |
You just open a chart for this symbol by manually typing the symbol. Refer to: File Menu: Find Symbol (File) The search feature only works with the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
