Date/Time: Tue, 11 Feb 2025 13:21:20 +0000
alert manager default settings
View Count: 1084
[2019-04-02 15:10:57] |
User902167 - Posts: 31 |
How can i change default settings in alert manager for symbol alerts comparison column from "CrossesOrEqual " to Above ?
[2019-04-03 15:58:17] |
There is no default for this. Maybe we could add a Duplicate command to duplicate an existing alert.
[2019-04-03 16:49:57] |
i like how quick it is to enter an alert by just putting in price and hit enter and done but the default cross or equal to gets missed too many times by gap up or downs in price, so now its more work to change comparison column each time then on to the price, I do lots of alerts each day and this is a needless pain if i could just change the default to above or below so no matter if it gaps i get the alert. If you use a duplicate command i would still have to change symbol each time so still more work.
[2020-09-06 10:21:05] |
Dušan Javnický - Posts: 1 |
Previous user has true. If you change size of window (when you need a place) the button Goto chart is too far. If an alert is shown you want to go the chart quickly. Could you put shortcut for Goto Chart? It will be helpful. Or faster.. choice if you click on alert row you will go to the chart immediately. Thank you very much. |
[2020-09-06 15:51:55] |
User90125 - Posts: 715 |
+1 |
