Date/Time: Thu, 26 Sep 2024 23:29:45 +0000
How come I can't get the Vol x Price to line up with the bar numbering
View Count: 631
[2019-04-02 14:27:20] |
User357195 - Posts: 123 |
SC: If what I am saying is untrue then why can't I get the bar numbering to count every 7 bars of 45 seconds each like the Vol X Price does? I have attached a screenshot of my chart below. http://www.sierrachart.com/image.php?Image=1554214960377.png As you can see, the chart is counting every 7 bars but it is not starting at the start of each Vol X Price line. The yellow line is the volume x price. Thanks. |
[2019-04-02 18:30:20] |
Ackin - Posts: 1865 |
Hi, There is only a shift, you do not have it well synchronized with each other....It is possible that this will start when you reset the start of the new day. If there is a slow market and the bar for a time period has the open, close, high and low as the same price, then your bar numbering indicator is not counting that bar.
study bar numbering is working
[2019-04-05 14:34:35] |
Thanks, Ackin.
