Date/Time: Fri, 31 Jan 2025 00:16:06 +0000
GPU use
View Count: 1629
[2019-04-02 13:27:17] |
User661434 - Posts: 27 |
Some files like TPO files take a lot of CPU power, I know I can reduce this by loading less days. Is there a functionality to let the GPU do the math? (or considered to do so?) Thanks |
[2019-04-02 14:49:44] |
samual sprat - Posts: 343 |
See this thread. Not sure if they're planning on doing GPU acceleration on the number crunching side but the chart rendering will be accelerated What is Sierra Chart Working On | Post: 174500 |
[2019-04-02 18:07:19] |
The load from the TPO charts is going to be related to drawing which will be improved upon with OpenGL support in an upcoming version. The calculations do not present barely any CPU load.
