Date/Time: Fri, 31 Jan 2025 00:18:05 +0000
Connect CTS+IB
View Count: 713
[2019-04-02 13:25:31] |
User00111 - Posts: 111 |
Please let me know how to set up data feeds in Sierra CTS with my account in Interactive Brokers that I would only use to trade. ---- A. Date Time Of Last Edit: 2019-04-02 13:26:49
[2019-04-02 17:35:14] |
To use CTS, refer to this page: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php If you are asking about using a better quality data feed with Interactive Brokers use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Please do not mess around with CTS. We are not going to provide any support for that at all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-02 17:35:20
[2019-04-02 18:15:35] |
I want to use Sierra Chart Exchange Data Feed but I not understund to trade via Interactive Brokers what should I do ? --- A. |
[2019-04-02 21:25:51] |
The instructions for this is explained here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
