Date/Time: Fri, 31 Jan 2025 00:14:51 +0000
TPO profiles - best combination of tick size * price increment
View Count: 1665
[2019-04-02 09:38:22]
User365411 - Posts: 192
On 6E futures and most of Forex pairs tick size minimum is 0.00005.
If i need that each TPO letter correspond to 2 ticks, which combination of (tick size * price increment) is better to use in terms of efficiency and correct results:
a) 0.00005 * 4
b) 0.0001 * 2
c) 0.0002 * 1
Thank you
[2019-04-06 04:30:13]
We do not recommend altering the Tick Size in the chart. That needs to remain the same.
You just need to change the Price Increment for the TPO profile chart study to what you need.
Date Time Of Last Edit: 2019-04-06 04:30:27
