Date/Time: Fri, 31 Jan 2025 00:20:30 +0000
Free Trial
View Count: 872
[2019-04-01 19:51:03] |
User223552 - Posts: 2 |
I downloaded SC this morning to begin a free trial from a third party. Their study is supposed to appear in the Analysis dropdown on the chart menu, but does not. I tried to add it in the custom studies but when I do part of it appears on the chart briefly before SC disappears. (closes).
[2019-04-01 23:32:18] |
Okay this means that study has some problem causing Sierra Chart to abnormally shut down. Do not use it and contact the developer about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-01 23:32:26
