Date/Time: Fri, 31 Jan 2025 00:05:33 +0000
Renko chart question
View Count: 1190
[2019-04-01 19:23:58] |
Glenn Infinity - Posts: 103 |
there is an issue on the Chart Settings with Sierra Charts when setting up a Flex Renko Chart where the “Setting:” does not allow for double digits in two of the number locations. For example, I wanted the setting to be 5-2-10 (i.e., I wanted a 5 tick bar size, a 2 tick trend, and a 10 tick reversal). But, Sierra Charts would only allow 5-2-1. It immediately erased the 0 when I clicked the mouse on anything including “Apply”. The Setting: field should allow for digits in the following array: xx-xx-xx. As it is now, it appears that the allowable array is: xx-x-x. please advise...thanks |
[2019-04-02 06:17:47] |
Refer to the Reversal Offset setting here: Renko Bar Charts: Flex Renko Instead use this particular Renko bar type: Renko Bar Charts: Flex Renko Inverse Setting Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-02 06:18:02
