Date/Time: Fri, 11 Sep 2026 14:48:56 +0000
[User Discussion] - View the CPU load that Sierra Chart uses
View Count: 1118
[2019-04-01 19:12:21]
Dorian - Posts: 70
It would be interesting to display the CPU load that Sierra Chart uses in real time in the connection bar at the top. And that it turns red when Sierra Chart uses a load greater than 12.5% for an 8-core processor.
[2019-04-01 23:49:25]
Acro - Posts: 459
I'd recommend Process Hacker Dorian.
I use it and I think it shows you what you are looking for
[2019-04-02 23:47:41]
Dorian - Posts: 70
Thank you very much.
[2019-04-03 01:39:37]
Acro - Posts: 459
Dorian,
BTW this is what I think you meant - see screenshot
imageProcessHacker_2019-04-02_21-38-46.png / V - Attached On 2019-04-03 01:39:26 UTC - Size: 40.45 KB - 437 views
[2019-04-04 10:38:47]
Dorian - Posts: 70
I wanted to see what Sierra Chart only uses in real time, and it works. Thank you :)
For an 8-core processor, 100% / 8 = 12.5
Sierra Chart should not exceed 12.5% of use.
It happened to me to go up to 16% sometimes. So I did: File: New Instance and I opened the DOM. I went from 5 frames / second to 40 frames / second.
Sierra Chart: 8%
Sierra Chart Instance (with DOM): 1%
Date Time Of Last Edit: 2019-04-04 10:43:05
image2019-04-04_12-27-14.png / V - Attached On 2019-04-04 10:33:41 UTC - Size: 47.76 KB - 421 views
