Date/Time: Fri, 31 Jan 2025 00:14:27 +0000
tariling stop to breakeven IB
View Count: 700
[2019-04-01 18:13:43] |
User996274 - Posts: 94 |
on sim mode (havent confirmed live) my stops do not trail to breakeven I do not have this problem in an older version of sc with amp Is this something unique to IB? Also, My auto trade system has (NO) when asked weather to "evaluate on bar close" yet it does not close the trade after the auto trade "exit" signal is initiated again it seems to work fine on the older version of sc with amp Date Time Of Last Edit: 2019-04-01 18:50:51
[2019-04-02 09:16:36] |
on sim mode (havent confirmed live) my stops do not trail to breakeven How did you set up this functionality? Did you use what is documented here:Attached Orders: Move to Breakeven for Stop We also see you are using version 1700. This is an older version. You need to update to the current version. At this point we are declining further support until you update. Also, My auto trade system has (NO) when asked weather to "evaluate on bar close" yet it does not close the trade after the auto trade "exit" signal is initiated again it seems to work fine on the older version of sc with amp Automated Trading Management: Troubleshooting Automated Trading System Behavior Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-02 09:17:53
[2019-04-02 11:33:17] |
I only went back to 1700 last night to determine if there was any difference in response Prior to that I had the latest version I did set up trailing BE as documented I have an accnt with Amp as well using the same set up (1700), seems to work fine I have no issue while using version 1700 Fwiw the trade window/dom in the latest version is not as stable as the earlier versions (data is not saved to dom) in regards to the auto trading it is not a programming issue as it works properly with AMP/SC1700 Date Time Of Last Edit: 2019-04-02 12:35:25
[2019-04-02 18:01:12] |
The Trade Window is definitely fine in all versions. The settings are saved with each individual chart and are permanently saved when you save a Chartbook: Chartbooks (Workspaces) There simply could not be a problem with this at all. No one ever reports an issue with this and there is not an issue. For possible reasons why there would be a problem with the Move to Breakeven functionality, refer to: Order Types: Sierra Chart Management of Trailing Stop and Chase Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
