Date/Time: Fri, 31 Jan 2025 00:11:52 +0000
Countdown Timer: Time elapsed since the start of the current bar
View Count: 932
[2019-04-01 17:50:09] |
ticinotrader - Posts: 401 |
Dear Support, I am looking for a function/option to display something similar to what is already available with the Countdown Timer Study, but instead of displaying the time remaining until the close/completion of the current bar, I am looking for to numerically display the elapsed time (in seconds) since the last bar (or the open of the current bar). Can you please let me know how can I accomplish this or can you add this function to the Countdown Timer Study? Thank you. |
[2019-04-02 09:19:44] |
You will need to modify that study to meet your requirements. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-02 10:48:23] |
Ackin - Posts: 1865 |
@ticinotrader Hi, just the size of bars or the property of a bar according to the type of chart? I'm going to remake the study, it's not complicated, but I need to know more what you want. send me a DM if you want |
[2019-04-02 11:18:44] |
Thank you Ackin - I have just sent you a direct message with a reply and my contact details. Regards, tt |
