Date/Time: Fri, 18 Sep 2026 23:33:40 +0000
Remote built not working
View Count: 1813
[2019-04-01 16:11:52]
User657944 - Posts: 173
Hi I'm trying to built or modify sierra study starting from a code in note pad , saved as .cpp file as per your istruction but when I arrive to the "built from remote" I get error messages like "#include "sierrachart.h"" but in fact the string is present into the study on the top.
Or as an example I tried to modify a std study the Tradying system based on alert condition just changing the draw style from point to a triangle and also that one did not work.
Can you please tell where the issue is? I'm an infinity trasact user and I already had a call with them but they told me they can't support me in this field.
thx
Alberto
[2019-04-01 16:52:53]
Provide the exact build output text. You can select it and right-click and select Copy. And then paste it here.
Date Time Of Last Edit: 2019-04-01 16:53:02
[2019-04-01 18:18:23]
Thx for answering Here the error code, consider that the #include "scstudyfunctions.h" is present and is the second row of the code as indicated in the istruction manual:
-- Starting remote build of Custom Studies Source files: numberbarzero.cpp. 32-bit -- 20:16:38
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
numberbarzero.cpp:2:30: fatal error: scstudyfunctions.h: No such file or directory
compilation terminated.
-- End of Build -- 20:16:39
Date Time Of Last Edit: 2019-04-01 18:19:17
[2019-04-01 18:27:13]
I got the same message also if I try to change the Trading system based on laert condition simply modifying the size of the point from 5 to 8
-- Starting remote build of Custom Studies Source files: TradingSystemBasedOnAlertConditionver1.cpp. 32-bit -- 20:25:56
TradingSystemBasedOnAlertConditionver1.cpp:2:30: fatal error: scstudyfunctions.h: No such file or directory
-- End of Build -- 20:25:57
[2019-04-01 19:10:46]
Sierra Chart - Max - Posts: 5967
You need to replace:
With
#include "SCStudyFunctions.h"
The included files need to have the proper case.
Sierra Chart Support
[2019-04-01 19:38:32]
Thx Max appreciate
[2019-04-02 06:15:01]
You cannot use SCStudyFunctions.h.
Remove that line.
[2019-04-02 07:19:46]
HI Max,
well since you was so kind to solve my issue I have another issue always on asci code study and it is as follows:
If I take a dll file with studies that are made by a friend, this studies are visible under custom study, but then when I try to add a study that is part of this directory on the charts, I don't see the study. What could cause such a failure? My friend is using sierra account while I'm using a ATchart sierra accounts, more over he developed the study wiht 1825 version and I'm using 1881. I don't get any error code from the system just I have no visibility of the study on the chart.
I will appreciate your help.
Thx
Alberto
[2019-04-03 13:30:03]
Hi can you please take care of my request? thx
[2019-04-03 16:34:21]
We cannot answer post #8. You need to contact the developer of the study.
Here is some information which is related but not probably relevant to your problem:
Resolving Custom Study File and Access Issues
Date Time Of Last Edit: 2019-04-03 16:34:37
[2019-04-03 18:26:58]
ForgivingComputers.com - Posts: 1238
When I try to add a study that is part of this directory on the charts, I don't see the study. What could cause such a failure? My friend is using sierra account while I'm using a ATchart sierra accounts, more over he developed the study wiht 1825 version and I'm using 1881. I don't get any error code from the system just I have no visibility of the study on the chart.
It could be it was compiled as a 64-bit DLL and you are using 32-Bit Sierra Chart, or vice versa.
[2019-04-04 13:33:22]
No it's a 32 bit and I'm using 32 bit it's not so easy
[2019-04-04 13:36:30]
Reeply to Sierra Engineering all the option on the link were verified it's not that the issue
