Date/Time: Thu, 30 Jan 2025 23:59:08 +0000
Live Price are not getting updated
View Count: 656
[2019-04-01 14:17:44]
EquinoxAnalytics - Posts: 10
Hi I have subscribed to Market Live data, When i am connected to my 1st PC (1st connection ) i see live Price. but when i connect to 2nd Connection on 2nd PC i do not see live price of any product. if i disconnect and reconnect price then gets updated on 2nd PC.
Please help to get this issue resolved.
Best Regards
Manish
[2019-04-01 16:19:00]
You are not setup to receive the Sierra Chart Real-Time data on two different systems at the same time. You can either pay for the second connection by activating it here:
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures&UserID=164988#DataConnections
Or, if you are using the second computer on the same network at the first, then you can use the DTC server to get the data to the second system. Refer to the documentation here:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
