Date/Time: Fri, 31 Jan 2025 00:17:56 +0000
Hide P&L from Trading DOM's trade window
View Count: 2787
[2019-04-01 13:12:34]
User515399 - Posts: 6
Hi, how do I prevent the P&L & Daily P&L from showing/updating in the Trade Window that is attached to the Trade DOM?
I am not referring to the P&L shown in normal Trade Windows of charts, nor the P&L column in the Trade DOM, but specifically on the Trade Window for the Trade DOM, which I do not find anyway to disable/remove it.
[2019-04-01 15:48:16]
John - SC Support - Posts: 37621
It is not possible to remove the display of the P&L and Daily P&L from the Trade Window.
In order to remove the Trade Window from the Trading DOM, select Trade >> Attach Trade Window to Chart Window, this will detach the Trade Window from the DOM, then you can click the x in the upper right corner to close that Trade Window, which will leave you with just the DOM. You will find documentation for this here (which gives another way to do this as well):
Chart Trading and the Chart DOM: Detaching Trade Window
[2019-04-01 17:34:22]
Actually you can do this by setting the Profit/Loss Format to Do Not Display:
Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu)
Date Time Of Last Edit: 2019-04-01 17:42:27
