Date/Time: Fri, 31 Jan 2025 00:22:28 +0000
Chart Values Window
View Count: 1125
[2019-04-01 12:41:23] |
User863606 - Posts: 1 |
Hello, The following values stopped working, Open, High, Low and Last, whenever I use the chart values tool on any bar. I don't know why! Does anyone know how fix this? |
[2019-04-01 16:51:29] |
If you are displaying a TPO Profile Chart, then this will be the case, as the underlying Bar data is not available when the TPO is displayed. Make sure you are looking at the Tool Values window: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Otherwise, please attach a screenshot of what you are seeing so we can better understand the issue. Follow the instructions here for how to attach a screenshot: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Use the Edit >> Screen Images >> Upload Chart with Overlays so we can see the Tool Values window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-01 16:52:14
