Date/Time: Sun, 24 Nov 2024 16:32:58 +0000
Compiler
View Count: 1165
[2013-11-19 19:43:12] |
ABeyer - Posts: 10 |
I reinstalled Sierra today to clean up things, but now the compiler does not work anymore. I installed and deleted it several times, but I always get the same error messages (attached). I work on Windows 7 and before it worked well. What can be the problem?
Compiler error.docx - Attached On 2013-11-19 19:40:43 UTC - Size: 60.22 KB - 388 views |
[2013-11-19 21:23:48] |
We will test this.
