Date/Time: Fri, 31 Jan 2025 00:00:31 +0000
Bar Numbering indicator
View Count: 1520
[2019-04-01 02:07:06]
User357195 - Posts: 123
SC:
If there is a slow market and the bar for a time period has the open, close, high and low as the same price, then your bar numbering indicator is not counting that bar. For example, a 1 minute bar during the slow times of night for the 6E future, if the bar numbering is set to 5 then if the chart shows only one trade for that time period resulting in the high, low, open and close of that bar to be the same price, then your bar numbering indicator is not counting that bar as one of the 5 bars that it is set to count before displaying the bar numbering on the chart. Please correct the code accordingly.
Thanks in advance.
[2019-04-02 09:22:48]
We do not see what you are stating. The Bar Numbering study is correctly counting the bars that are displayed in the chart, even if the bar has the Open/High/Low/Close as the same price, and regardless of the setting for Number Every N Bars. See the attached picture for what we see when we use the study with a setting of 5.
http://www.sierrachart.com/image.php?Image=1554131116611.png
At this point we are declining further support. What you are saying is flatly untrue. We will ignore any further post from you on this.
Date Time Of Last Edit: 2019-04-02 09:23:10
