Date/Time: Fri, 31 Jan 2025 00:08:20 +0000
Time scale at bottom of charts
View Count: 1862
[2019-03-31 20:57:50] |
irvolsen - Posts: 12 |
How do I change the time scale at bottom of chart to not show day of week and date when chart values cross hair is active. See clip for what I see now.
time display.PNG / V - Attached On 2019-03-31 20:44:35 UTC - Size: 2.49 KB - 288 views |
[2019-04-01 08:54:22] |
Refer to these settings here: Chart Drawing Tools: Chart Values Tool Configuration (Global Settings >> Tool Settings >> Chart Values) Specifically the Date-Time Label Options for Intraday Charts section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-01 08:54:33
