Date/Time: Fri, 31 Jan 2025 00:27:36 +0000
ZN Format
View Count: 971
[2019-03-31 19:14:15] |
User417302 - Posts: 67 |
How do I change the ZNM19 price format to show as 124'070 (using settlement price as the example) instead of the current price shown as 124 8/32 that is used for settlement.
[2019-04-01 03:59:05] |
Refer to this particular section here about this: Changing the Price/Value Display Format: Setting a Fraction Display Format For Either the Main Price Graph or a Study (US Bonds) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-01 03:59:19
