Date/Time: Fri, 31 Jan 2025 00:20:46 +0000
Scale buffer at top and bottom of Chart or Study window
View Count: 1064
[2019-03-31 13:25:56] |
User629461 - Posts: 184 |
Is there an ability to specify a buffer (blank space) at the top or bottom of study or chart window to allow for any Drawings (eg text or marker) positioned above or below a price bar to be seen when scale is set to 'Automatic'? For example, I annotate volume bars with text at the top of the bar, however as the automatic scale adjusts to fit the largest bar in the window, anything draw above is not visible unless the scale is adjusted manually. Thanks
[2019-04-02 09:30:51] |
You need to use the Interactive Scale Range functionality: Chart Scale and Scale Adjusting: Interactive Scaling There is no further help we can provide. This is all. It will not help the post further about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-02 09:31:11
