Date/Time: Fri, 31 Jan 2025 00:14:39 +0000
Time and sales for symbol retrieving in replay mode
View Count: 1061
[2019-03-31 09:21:20] |
PK - Posts: 12 |
Hi, I use replay, and there is no sales data available when I call this function: // Get the Time and Sales c_SCTimeAndSalesArray A_TimeSales; sc.GetTimeAndSalesForSymbol(s_BaseCurrency, A_TimeSales); does this sc.GetTimeAndSalesForSymbol work in replay mode? |
[2019-04-02 03:54:04] |
Do you want to get time and sales data for the symbol of the replaying chart or a different symbol? You will not be able to access the time and sales data for a different symbol during a replay. Or if it is accessible, it would not be based on the replay of that chart.
[2019-04-02 03:59:58] |
PK - Posts: 12 |
yes, I would like to access the time and sales data for a different symbol during a replay. Could you advice how to get it? Thanks. |
[2019-04-03 02:08:12] |
This is not currently supported but we are seeing if we can add support for this. You would still use the same function you are and it will work during a replay. But the chart for that symbol will have to be open and replaying as well.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-03 02:08:58
