Date/Time: Fri, 31 Jan 2025 00:05:48 +0000
Keyboard Shortcuts linked to a specific #n chart
View Count: 1359
[2019-03-31 08:13:38] |
User993113 - Posts: 74 |
Dear support, I manually trade on many charts and sometimes I would like to use a keyboard shortcut to activate a "Trade Management by Study" or a "Spreadsheet System for Trading" resident in a specific chart without having to select that chart to use the keyboard shortcut because it is a slow procedure, so I kindly ask: 1 - Is it possible to set up an "ACS Control Bar Button Keyboard Shortcuts" to Enable/Disable a "Trade Management by Study" resident in a specific chart (i.e. #3) not having to select #3 chart to use the keyboard shortcut? 2- Is it possible to set up a a keyboard shortcut to Enable/Disable "Auto Trading Enable - Chart" in a chart (i.e. #5) with a "Spreadsheet System for Trading" not having to select #5 chart to use the keyboard shortcut? Thank You |
[2019-04-01 03:01:10] |
1, 2. No, we do not see something like this being supported. We recommend you develop a solution using the external program "auto hotkey" for something like this. That program should be able to send keyboard commands to any window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
