Date/Time: Fri, 31 Jan 2025 00:16:45 +0000
Scaling Range Bars
View Count: 648
[2019-03-30 23:40:15] |
DGee - Posts: 82 |
I've duplicate a chart and made sure all the setting are correct however my range bars have squashed in my chart I cannot even view them. I've adusted for my view preference and as soon as I save my work it's back to a squashed mode. How do I set the range bars so that they don't change? I've attached pics to describe the situation.
Date Time Of Last Edit: 2019-03-31 03:14:16
Scaling.PNG / V - Attached On 2019-03-30 23:36:01 UTC - Size: 44.76 KB - 255 views Scaling2.PNG / V - Attached On 2019-03-30 23:36:14 UTC - Size: 28.75 KB - 256 views |
[2019-03-31 03:15:31] |
Move the Volume study in that chart to Chart Region 2. Also if you still have a problem temporarily Hide the other studies until you see which one is causing the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-31 04:32:55] |
DGee - Posts: 82 |
That did it. It had the ES VWAP indicator I duplicate over when creating a YM chart. Lesson learned. Thank you! DG |
