Date/Time: Fri, 31 Jan 2025 00:08:15 +0000
high/low bar with price display
View Count: 2088
[2019-03-30 17:37:28] |
User378226 - Posts: 15 |
Is there a study that automatically displays the price above/below the high/low bars in any whatever timeframe I select on the chart? If so, how do I set it up? Thanks, Mike |
[2019-03-30 17:58:13] |
Ackin - Posts: 1865 |
Try: High and Low Highest High/Lowest Low Over N Bars + Study Subgraph Add (if you want offset) https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=272#Study_Subgraph_Add edit: Attachment Date Time Of Last Edit: 2019-03-30 20:52:54
HL study.png / V - Attached On 2019-03-30 20:51:49 UTC - Size: 109.31 KB - 350 views |
[2019-03-30 20:30:45] |
Have a look at this study: Study Subgraph Above/Below Bar as Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-31 00:55:23] |
I tried both and they displayed high/low on every bar, however, I just need the highest and lowest bars with their values displayed above/below. For instance, if I am browsing a chart in 30min timeframe, I want to see just the highest/lowest bars, and same idea if I switch to 15min or 5min on the same chart. Is it possible?
[2019-03-31 07:13:35] |
1) High and Low Highest High/Lowest Low Over N Bars + 2 x Text Display For Study Text Display For Study 2) Swing High and Low Swing High and Low Date Time Of Last Edit: 2019-03-31 07:22:13
hl text.png / V - Attached On 2019-03-31 07:13:21 UTC - Size: 69.66 KB - 383 views hl text2.png / V - Attached On 2019-03-31 07:22:09 UTC - Size: 113.91 KB - 417 views |
[2019-04-01 01:21:32] |
Ackin, thank you, "value on high" I'll remember that!
[2019-04-01 01:55:32] |
In response to post #4, this can only be done for a trading day. To do this, use this study: Daily OHLC - Single Point Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-01 01:57:40
