Date/Time: Fri, 31 Jan 2025 00:09:40 +0000
Moving drawings between chart regions
View Count: 690
[2019-03-30 17:22:27] |
REKT4K - Posts: 8 |
Good day. I want to move price chart from region 1 to region 2, together with all existing chart drawings - is there any way to do it automatically on Sierra Chart? Switching price chart region from 1 to 2 is moving the price graph, but all drawings remain on region 1. Or maybe I can link the drawings somehow from region 1 to region 2 or whatever? Thx. |
[2019-03-30 20:31:33] |
This is not supported. A drawing cannot be moved between chart regions.
