Date/Time: Fri, 31 Jan 2025 00:26:43 +0000
Troubleshooting Spreadsheet System for Trading
View Count: 708
[2019-03-30 14:58:59] |
User94606 - Posts: 327 |
I am using the same formulas for Buy/Sell (entries/exits) for other indices such as NQ, ES, YM, RTY and it is working fine based on the formulas defined. However, using the same formulas, nothing is being triggered when I tried EUR when I ran Chart Replay this morning. If you look on March 29, 2019 at 5:31 AM EST on the 1 MIN CHART, the SELL entry should have been triggered. How do I troubleshoot this issue? I have attached the chart and spreadsheet.
Date Time Of Last Edit: 2019-03-30 16:06:14
Private File Private File |
[2019-03-30 20:29:12] |
Refer to: Automated Trading Management: Troubleshooting Automated Trading System Behavior The issue must relate to the smaller values of the symbol. Check the formulas carefully to see that they are handling those values in an unexpected way. This information might be helpful: Working with Spreadsheets: Floating-Point Values and Comparisons When Using the Spreadsheet Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
