Date/Time: Sun, 24 Nov 2024 16:55:41 +0000
how to plot a line on a chart from a spreadsheet formula
View Count: 1278
[2013-11-19 18:08:30] |
User61342 - Posts: 2 |
hello if i have a formula in a spread sheet cell and i want to plot the value of the formula on a chart by plotting a line , is it possible ? thank you |
[2013-11-19 21:50:53] |
Sawtooth - Posts: 4119 |
Yes, set the Draw Style of the respective subgraph to Line. This assumes the value is in one of the Formula Columns (K-Z...BR) |
[2013-11-20 02:51:20] |
The basic instructions for this can be found here: http://www.sierrachart.com/index.php?l=doc/doc_StudiesSystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
