Date/Time: Fri, 31 Jan 2025 00:16:09 +0000
Shades Value Area in Volume Profile
View Count: 1412
[2019-03-29 15:15:37] |
User274676 - Posts: 38 |
Hi. Is it possible to have the value area shaded across the chart like a horizontal box from the top of value and the bottom of value? Transparency fill? Right now I have the value extras extended. I want it the same but the entire value area region shaded?
[2019-03-30 19:33:19] |
John - SC Support - Posts: 37621 |
This can be done when displaying the Volume by Price study, but not when displaying the TPO Study. When the Volume by Price study is on the chart, add the Study Subgraphs Reference study to the chart and reference the Value Area High Subgraph and the Value Area Low Subgraph from the Volume by Price study. You will want to make sure you set the Scale for the Study Subgraphs Reference to Automatic, as it is set to Independent by Default. By default, the Study Subgraphs Reference study is set to display as a filled band. You will have to determine the best Subgraph settings for your needs. All of this is explained in the following documentation, or linked to from it. Refer to: Study Subgraphs Reference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
