Date/Time: Fri, 31 Jan 2025 00:20:33 +0000
References
View Count: 614
[2019-03-28 19:04:35] |
JDMontero - Posts: 34 |
Hi. 1) Need to reference the Low of the bar at entry price in Spreadsheets to place a stop after a buy entry. How could I do this? Also need to refer the ATR at the entry to set a profit target. Please advise. 2) Is there any course or legit Youtube channel to get started with ACSIL in a nicer way than loads of text in SC website? 3) I'm getting entries (in the spreadsheet trading system) that enter the trade two bars after the signal of the condition. Why is that? I see the green arrow right at my condition but then the entry is two bars later. Should I code the entry to be at the open of the next bar?? I supposed that was default. Please advise on how to enter at open of next bar after condition evaluated TRUE on bar close. Thanks! JD |
[2019-03-31 22:42:26] |
1. This is not within the scope of our support. 2. No. 3. Unless you are doing something unusual, this would not be expected unless there is a time stamping issue which could be the case if this occurs during real-time updating of a chart. But there should not be this kind of condition during a Chart Replay. Let us know if this happens during a chart replay. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-31 22:42:49
