Date/Time: Thu, 30 Jan 2025 19:00:11 +0000
chart sticking to 5min periodicity- wontr change
View Count: 653
[2019-03-28 15:11:11] |
Yeager - Posts: 128 |
I have my #7 chart stuck on 5min periodicity. Everytime I go into chart settings and chage it to volume based and 1000 tick volume, then click ok, it changes for a split second and then reverts back to 5min. Help much appreciated. The chart is linked but the time period is not synced. Strange activity. |
[2019-03-28 17:00:31] |
Refer to: Unable to Change the Bar Time Period for Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
