Date/Time: Thu, 26 Sep 2024 23:30:05 +0000
thinkorswim trade DOM market depth?
View Count: 3731
[2019-03-27 18:34:06] |
trader1 - Posts: 128 |
Hi, Can you please tell me how to get market depth in a trading DOM using thinkorswim? Although I have level2 I only am seeing the top level on the Sierra Chart trading DOM. Thanks. |
[2019-03-27 20:40:08] |
This is not supported.
[2019-03-27 21:41:18] |
Can you please point me to a list of brokers where this is supported for US equities? Thanks. |
[2019-03-28 09:27:06] |
The only possibility would be Interactive Brokers and here is the relevant documentation for that: Interactive Brokers Trading Service: Accessing Level 2 / Market Depth Data for Stocks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-28 15:42:55] |
So the depth of market for stocks when using IB can only show one specific exchange at a time?
[2019-03-28 17:19:10] |
Yes it appears like that. Interactive brokers though can answer this question the best.
[2019-03-28 17:47:19] |
I am going by your link. In that link it appears as though Sierra Chart doesn't support it: "To access Level 2 data for stocks in Sierra-Chart when connected to Interactive Brokers Trader Workstation, it is necessary that the symbol the chart is set to specifies the specific exchange code the symbol trades on. You cannot use SMART for the exchange code." |
[2019-03-28 20:38:43] |
Yes but maybe there is additional or new information from Interactive Brokers in regards to this. Although probably not.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-28 20:38:52
[2019-04-01 16:51:10] |
What would I ask them? Thanks. |
[2019-04-02 09:21:27] |
That is for you to figure out.
[2019-04-05 15:29:41] |
I can see all the level2 info in IB, so it appears as though it is a limitation in Sierra Chart. It appears as though the information is available to you should you choose to show it. If that is not correct, can you please explain why it is available to be seen in IB but not in Sierra Chart? Thanks. |
[2019-04-05 17:24:14] |
We cannot answer any of these questions. We cannot answer Interactive Brokers issues and limitations. How are we supposed to know the answer to these questions? You are coming to conclusions that you do not know about.
