Date/Time: Thu, 30 Jan 2025 18:57:00 +0000
Maximum Zig Zag Value Setting
View Count: 730
[2019-03-27 15:43:05]
User164231 - Posts: 278
Hi Team SC,
Is there a way to display max rotation value using SC zig zag study as per image?
Thanks.
imageValue at HH and LL.jpg / V - Attached On 2019-03-27 15:32:23 UTC - Size: 11.42 KB - 263 views
[2019-03-28 10:07:38]
Incorrect placement of the Line study in region #2. Setting up ZigZag-based Rotational chart
Answer is here guys.
[2019-03-28 10:55:17]
Yes, it can be done. The easiest way is to use the Spreadsheet Study and just check for when the Oscillation switches from Positive to Negative and vice versa.
