Date/Time: Thu, 30 Jan 2025 18:58:38 +0000
No alerts working
View Count: 660
[2019-03-27 12:07:48] |
bookert4 - Posts: 56 |
Hello Support, Since I downloaded version 1882, my "color bar based on alert condition" function is not operating. I have had these alerts operating for quite some time. Please advise |
[2019-03-27 20:33:54] |
You need to go through a process of troubleshooting/debugging where you change the formula to a simple formula of 1 and then gradually build up the formula to what you require and see what the problem is. Also enable this Alert settings option to help understand what may be going wrong: Study/Chart Alerts And Scanning: Log Evaluated Formula at Each Evaluation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-27 20:34:26
