Date/Time: Fri, 31 Jan 2025 00:03:47 +0000
sending attached orders
View Count: 1111
[2019-03-26 20:01:57]
SBTrader82 - Posts: 7
I am extensively using the "send attached order by position" feature.
I do this by right clicking on the chart or on the DOM. Is it possible to do this with a KeyBoard shortcut?
I can see there is a Keyboard short cut that says:
-BUY send attached order
-SELL send attached order
but I cannot see any "send attached order by position". I don't know if there is a way to do this.
[2019-03-27 01:39:13]
What you should see is as follows in Global Settings >> Customize Keyboard Shortcuts:
Buy Send Attached Orders - Position
Sell Send Attached Orders - Position
Date Time Of Last Edit: 2019-03-27 01:39:27
[2019-03-27 18:43:45]
yes, this is waht I see, but my question is if I can also send the attached order without specifying buy/sell attached order? this is an option it the chart trade menue and I was wondering if it was possible to have the same option when trading with the keyboard.
[2019-03-28 22:01:20]
We will need to add a new keyboard shortcut for this. We will do that.
Date Time Of Last Edit: 2019-03-28 22:01:27
[2019-03-28 22:05:12]
Thanks a lot, that will be very helpful
[2019-03-30 11:27:00]
This is in version 1892.
