Date/Time: Thu, 30 Jan 2025 18:59:23 +0000
Edge case for High/Low for Time Period study when it miscalculates
View Count: 632
[2019-03-26 19:59:46] |
User972768 - Posts: 166 |
Hello, I came across edge case when "High/Low for Time Period Study - Extended" miscalculates one of the lines. Configuration of test case: - ES intraday candlestick 0-5-0 chart for Mar 11, 2019 (set as "Use date range" 2019-03-11 .. 2019-03-11 in chart settings) Hope that my configuration is correct for case when I want to see only 1 specific session. Please find attached screenshots. Thanks and best regards |
ES_20190311.png / V - Attached On 2019-03-26 19:57:49 UTC - Size: 33.95 KB - 254 views Chart_settings.png / V - Attached On 2019-03-26 19:57:57 UTC - Size: 43.21 KB - 248 views Study_settings.png / V - Attached On 2019-03-26 19:58:05 UTC - Size: 33.69 KB - 260 views |
[2019-03-28 01:55:23] |
At first we did not know what you were referring to and there probably was a logical explanation for what you are seeing. But now that we look at this again we see that the study does not start at the first index. We will resolve this in the next release.
[2019-03-28 03:29:29] |
Thank you guys. Sorry that my message was not clear and thanks a lot for coming back to this ticket Date Time Of Last Edit: 2019-03-28 03:36:16
