Date/Time: Fri, 31 Jan 2025 14:46:33 +0000
Pulling Stacking color
View Count: 1285
[2019-03-26 19:06:56]
User48838 - Posts: 121
Would it be possible to someday add the ability to have different colors for positive numbers and negative numbers. TY
[2019-03-27 20:51:25]
Yes we will put that down as new color settings to add.
Date Time Of Last Edit: 2019-03-27 20:51:53
[2019-04-28 22:31:06]
I noticed this feature has been added to Chart, Graphic Settings and Global Graphic Setting. TY. When I changed the Negative choices to Yellow, the negative numbers on the DOM were still the default, green/red.
[2019-04-28 22:54:48]
In fact, when I rebooted my pc the Negative yellow settings had reverted to the default green/red
[2019-04-29 02:41:05]
Acro - Posts: 441
I don't think this has been enabled yet even though it is in graphic settings.
SC, will this be enabled in the next release ?
[2019-04-29 06:23:17]
Yes this has not yet been implemented even though the color settings are there.
[2019-05-15 15:36:40]
Another issue with pulling and stacking happens sometimes where the 'stale' pulling/stacking data is not cleared as the bid/ask moves away.
Chart attached.
TY
attachment2019-05-15_11-11-11.pdf - Attached On 2019-05-15 15:34:58 UTC - Size: 16.78 KB - 356 views
[2019-05-16 03:27:43]
This may be a data feed specific issue. We see you are using Gain Capital. See if you encounter this with the Sierra Chart Exchange Data Feed:
We would not expect that and we do not observe this ourselves with our own data feed. You can try the data feed for 5 USD.
Date Time Of Last Edit: 2019-05-16 15:01:29
