Date/Time: Sat, 04 May 2024 16:43:45 +0000
Market Depth Historical Graph and WIDE!!! price ranges
View Count: 4674
[2020-07-01 00:01:36] |
whats1thingnow - Posts: 407 |
works perfectly! way to go :)
[2020-08-06 19:11:53] |
Spartan79 - Posts: 54 |
Post #5 I guess what we need here is this to work automatically with the vertical scale zooming in and out.
Would that be possible in SC? To have the levels combine/ merge automatically as we zoom out price scale. Looks like the logic is already there, but with just price scale. |
[2020-10-30 19:33:45] |
John - SC Support - Posts: 31362 |
We have added the ability to automatically combine increments in the Market Depth Historical Graph, based on the scaling of the chart. There is a new Input called "Automatic Combine Increment Adjustment Value" that when set to a non-zero value will control how much of a change is needed in order for the increments to be combined. This will allow you to control when the combination occurs. A value less than 5 is not allowed. The smaller the number, the smaller the "boxes" need to be before being combined. The larger the value, the larger the boxes will be when combined. The value is based on Pixels, but it is not meant to be used mathematically, rather it is to be an adjustment knob to tweak to where you like it functioning the best. When using this option, if you are also using the Lowest/Highest Quantity to Color options, you will want to use those based on Percentages, as each change in the combined increments will change the Maximum and Minimum quantities in the chart. This change will be in the next Pre-Release - v 2190. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
