Date/Time: Sun, 23 Feb 2025 18:48:35 +0000
trade with ib
View Count: 947
[2019-03-25 10:02:36] |
user - Posts: 78 |
hi , I want to trade with ib , but use sierra chart datafeed. When i choose interactive broker inside "data/trade service setting", i lose the realtime data connection with sierra. Plz advise how can i fix it!! Thanks! |
[2019-03-25 10:56:31] |
Follow through the instructions here in regards to this: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices You need to make sure you are using the Interactive Brokers symbols for the charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-25 10:56:36
