Date/Time: Fri, 31 Jan 2025 00:02:43 +0000
1888 slower than 1881 for custom text tool
View Count: 687
[2019-03-24 14:24:56] |
Acro - Posts: 441 |
Hi, I updated to 1888 to take advantage of the trading activity log improvements. However, I am finding that the custom text drawing tool is much slower in this version. By that I mean where you insert a custom text drawing (eg via a toolbar button) it draws the shape quickly but then there is some delay before the text appears on that shape. FYI I have reverse colors turned on for the custom text drawing tool and I believe that is the issue - ie if I turn it off then the drawing appears quickly but if I have reverse colors on then the text is very slow to appear Resolved by 1889. All fine now Date Time Of Last Edit: 2019-03-25 02:49:34
[2019-03-25 18:04:19] |
We will check on this.
[2019-04-03 06:07:58] |
This is actually nothing new. We looked into this and resolved it. It was an old issue (actually intentional design related to exclusive or drawing) that goes back many years ago which has now been corrected.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-03 06:08:37
