Date/Time: Sun, 24 Nov 2024 17:00:03 +0000
M6E on OEC using Sierra Chart Data Feed
View Count: 1222
[2013-11-19 13:37:48]
drw112 - Posts: 24
I'm having quite a bit of trouble getting SC data feed to work with m6e. I've updated the symbols, I tried adjusting the real-time multiplier in the symbol settings but it doesn't seem to affect the real time data. Historical data can be adjusted by applying 1000x multiplier but real-time doesn't seem to be affected by the multiplier.
OEC uses a 100x multiplier on FX futures.
[2013-11-19 18:01:31]
We are going to check on this. Just give us about an hour.
[2013-11-19 20:23:04]
Still working on this. Just a few more minutes.
[2013-11-19 20:54:07]
We apologize for the delay with this. This is now resolved. Follow the instructions here to update the symbol settings:
http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings
After you have updated the symbol settings, reconnect to the data feed with the commands on the File menu.
You will also need to re-download the data in the chart by selecting Edit >> Delete All Data and Download.
[2013-11-19 21:02:04]
drw112 - Posts: 24
Working better, thanks for the help.
