Date/Time: Thu, 30 Jan 2025 19:16:08 +0000
Extend Bid-Ask Bars Vertically on Trading Chart DOM
View Count: 775
[2019-03-21 19:08:09] |
User429065 - Posts: 128 |
How can I "extend vertically" the horizontal Bid-Ask Bars on Trading Chart DOM similar to Bookmap? I believe they simply retain the last known bar. See attached. Thank you!
Date Time Of Last Edit: 2019-03-26 20:20:44
BidAskColumn Extended.PNG / V - Attached On 2019-03-21 19:04:54 UTC - Size: 97.76 KB - 276 views |
[2019-03-26 12:57:23] |
Is this post seen by anyone? Almost a week and nobody is responding.
[2019-03-26 13:30:47] |
Ackin - Posts: 1865 |
There is no public imageFile attached Date Time Of Last Edit: 2019-03-26 13:33:28
[2019-03-26 20:22:12] |
I believe the attachment is now public. Can it be seen now?
[2019-03-27 20:38:53] |
There has been no response because we are not understanding this and it sounds like something that is not supported anyway. Maybe you are referring to the current market depth data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-27 20:39:42
