Date/Time: Fri, 26 Apr 2024 16:44:04 +0000
How do I get rid of selection box around TPO Profile Chart
View Count: 576
[2019-03-21 01:57:44] |
User785437 - Posts: 5 |
Hi, I was wondering if there is a way to get rid of the selection box when I click on the tpo profile? Thank you |
[2019-03-22 05:18:03] |
You have to disable keyboard shortcuts for TPO Profiles to prevent that: Time Price Opportunity (TPO) Profile Charts: Keyboard Shortcuts for Splitting and Merging Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
